Farmall H exhaust manifold
MattK1234
10-18-2006 13:54:28
I am looking to buy a new exhaust manifold for a 1944 farmall H. THe number on the manifold is 6712DB. However, the only new manifolds i can find say they replace OEM 8033DC, 362536R21. Any suggestions or anyone know if this manifold will work. Also, does anyone know if there is a certain chrome stack i need to fit on this manifold.
Thanks,
Matt
Brian in NY
10-19-2006 06:16:06
 Re: Farmall H exhaust manifold in reply to MattK1234, 10-18-2006 13:54:28
I have purchased two really nice used ones from Mike at Steel Wheel Ranch. Saved a lot of $ and fit perfect too.
GordoSD
10-19-2006 03:57:47
I have an extra H manifold. Email is open.
Gordo
Larry in CO
10-18-2006 19:06:17
Check out your local CNH dealer or get in touch with Bermuda Ken at Carter & Gruenwald, cngco dot com. They"ve got one that fits like a glove. I think they are $125 - $140 ant that includes the gaskets and exhaust stack. You can also check out the parts over to the left on this site. HTH. Larry
Deerely B Parted
10-18-2006 18:27:46
There was a peddler at Florida Flywheelers this past January that hawked exhaust manifolds for the H; seems like they were of the order of $125. He was based in Indiana just south and a little east of IPLS, e mail me if interested and I will forward information such as you'll need to contact him. J Howard
Wardner
10-18-2006 16:07:12
The exhaust pipe is just schedule 40 pipe which is available at Home Depot or similar outlet. If you want it shiny, go to a steel service center and get stainless steel. Have one end threaded. It can be polished in a lathe.
I have a small supply of stainless pipe discards and a threader. I always replace with SS. Y'know, that might be a good business.
NDS
10-18-2006 16:06:41
Have seen a couple of the aftermarket H manifolds where the bolt holes for carburator would not line up. Was able to drill and file to get them to work though.
RustyFarmall
10-18-2006 14:12:32
There were only two different styles of manifolds used on Hs. the hot manifold for Distillate/kerosene fuels, and the cold manifold used for gasoline. As far as I know, the only one of these being reproduced is the cold manifold, and I believe those are made to fit everything from the H up through and including the 350. The exhaust pipe is nothing more than a length of two inch diameter black pipe that threads into the manifold. It is about 10 to 11 inches long. The muffler then installs onto this pipe. Any chrome stack that will slip over the two inch black pipe will work.
MattK1234
10-18-2006 14:24:59
 Re: Farmall H exhaust manifold in reply to RustyFarmall, 10-18-2006 14:12:32
Thanks for the helpful information.
