voltage drain?
Russ Lowry
10-18-2006 16:03:51
Afternoon guys, yet another question....I rewired my Farmall Super C over the weekend, put in a brand new battery and new ammeter. I went to show the neighbor how nice the lights work and I had a dead battery! The previous wiring was a disaster with every color wire you can think of going in every direction! It is a 12 volt conversion with alternator. I followed the wiring diagram I found on this web site for an "H". Somewhere I am getting a voltage drain. The previous owner had replaced the ignition switch, I rewired back to the original one, it is 2 polled. Now, my light switch (original) works like this...Off. one click to the right and it turns on the back-up light, one more click to the right and the headlights and the back-up light come on. When the battery was charged, the tractor starts and runs good. Any ideas of what I might have done wrong? Or where the voltage draw is coming from?? Thanks a ton... Russ
current drains
10-18-2006 17:43:32
 Re: voltage drain? in reply to Russ Lowry, 10-18-2006 16:03:51
to be technically correct, it is current that drains, not voltage. Current is like water under pressure and voltage is the pressure that makes current move.
El Toro
10-18-2006 17:06:51
I think you need a warning light installed. Take a look at Bob M's wiring diagram No6. Hal
http://albums..photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=63226495&/=0
Janicholson
10-18-2006 16:39:05
The problem can be found with minor trouble shooting.
First charge the battery with the pos post disconnected from the tractor cable. Leave it disconnected.
Next use a portable/handheld volt meter to check the drain as follows:
1- Place the red lead from the volt meter on the positive post of the battery (use a locking pliers, or small C clamp, to keep it on there, being careful to not ground the pliers/clamp.
2- Place the black lead on the cable clamp that usually goes on the positive terminal but was disconnected above.
3- Look at the reading, if there is a major drain on the battery it will read 12 or more volts, maybe 12.6. If there is no major drain, it will read less than one volt.
If it reads 12+ volts, begin by disconnecting one wire at a time, then checking the volt reading and reconnecting the wire if it is still at 12+ volts Use this order of disconnect.
Alternator big wire from alternator. If volts drop, it is probably bad diodes in the alt.
Alt other wires one at a time. If these it may need an internal voltage regulator.
Light switch power lead from fuse/amp meter. If this is it, the switch is wired incorrectly or bad.
Big Wire from starter switch to starter. If this is it the switch may be bad leaking current when off.
Smaller (about #10)wire from start switch to amp gauge. If this is the problem, the wire, or amp meter may have a short to ground. Good luck, John T has a trouble shooting guide on this site in the archives. some of it is for gen systems and other parts for alt systems, good luck, JimN
Finally wire from
