Adjusting TA
mulcher
10-18-2006 17:42:25
Did the adjusting of the TA on my 1586 after reading old posts on here and reading the IT manual for my 1086. Got the snap ring set down snug and added a half turn. When the plunger comes up and there is suppose to be 1 1/8" I only have 7/8". Is that OK? Had trouble setting the dump valve also like the book says. Have it now so lite goes off just before clutch engages. Also set free play and trans brake. The 1086 will almost lift the front wheels off the ground when you shift to direct but the 1586 is lot slower shift and smoother and made me wonder which is right? Enjoy reading all the posts.
Brian
the tractor vet
10-18-2006 18:55:48
 Re: Adjusting TA in reply to mulcher, 10-18-2006 17:42:25
IF you fallow my way of setting a Hyd. T/A then ya can not miss as for the book don't know anybody that does it that way . as far as the control valve ya need to go back to that and get it set for full up and all the way down to the snap ring as for the half turn more i don't do that as long as it is against the nut then all is well in Whoville. and as for getting into this evening i am towhipped after 40 trips up and down the basement stairs maken shims for the one wall in the living room so that the drywall will lay flat. So go back over any of my posts on settting a hyd. T/A and go from there if ya got questions we'll cover them later . As for the frem shift on the 1086 verses the 1586 here i would have to check the pressure on the MCV as the 10 may be set higher or the 15 may need some attenshion.
vernMN
10-19-2006 03:26:24
 Re: Adjusting TA in reply to the tractor vet, 10-18-2006 18:55:48
Vet, I thought the office was closed for the day. Just couldn't stay away. Good to see the house hasn't taken all your spunk away. Take care.
