340 power steering line leak
old
10-18-2006 18:43:34
Got this 340 and where the line goes into the bolt on block at the steering wheel one of the 2 lines leaks. Its not from the o-rings but the line its self. Can a guy braze up this line to stop the leak and or can you still buy new lines for it??
Thanks
Brownie 45
10-19-2006 04:45:18
 Re: 340 power steering line leak in reply to old, 10-18-2006 18:43:34
Heat the metal until you can see it "sweat" then add the brazing rod in small quantities. Use flux coated rod or dip bare rod in flux sparingly. The line probably cracked from vibration or fatigue, & brazing will "spread" the fatigued area as you work, making a good repair job.
Janicholson
10-18-2006 20:14:06
Old,
Brazing will work Braze a steel patch over it if it is a hole. cover the sides 1/4" or so. If it is a crack near the fitting/block, I would braze weld (meaning build up some thickness to the bronze) to help it stop cracking. Don't over heat the bronz, the zink will vaporize out of it and it will be no where near as strong. If white smoke and bright firelooking things are happening it is too hot. From my experience. Good evening to you, JimN
the tractor vet
10-18-2006 19:02:46
Well if you are good with a tourch and real good at brazen then have at it .
old
10-18-2006 19:29:14
 Re: 340 power steering line leak in reply to the tractor vet, 10-18-2006 19:02:46
Well I'm a pretty good welder and I also at one time did a lot of soldering so I figure I should do ok with brazeing, I hope.
