M starting problems
Granger
10-19-2006 07:59:51
As the weather continues to get colder, I went to start tractor last night to drop a round bale & it did not want to start up. It would crank over three times & then stop. I would push the starter again & it would do the same, until about on the 10th try, it finally cranked over. I have never had to plug in the tractor in past winters & it would start up fine. Once tractor was warmed up I re-started it & it started right away. All the wiring connections are clean & I recently went from Champion plugs (18's) to Auto-Lite (21's). Can you help me out on what to do now or where to look to fix problem?
Jossette
10-19-2006 16:12:35
 Re: M starting problems in reply to Granger, 10-19-2006 07:59:51
do you throw the idle wide open before you crank it and bring it back after the 2nd crank? works every time even with a low battery or bad starter.
plugging it in saves a lot of wear and tear....
Janicholson
10-19-2006 13:32:58
The Tractor Vet, and John T may have it, I'll add that if it was hard to turn on one cylinder, and took tries to get it past that cylinder, I would suspect water might have gotten in the cylinder. Windy wet wether can push a flip cap up and allow water into the exhaust. Even a half chamber full can increase the compression to the point of not getting past it. A leaky head gasket will also fill a cylinder such that it will hydro lock. Just Ideas to ponder, JimN
Granger
10-20-2006 11:54:20
 Re: M starting problems in reply to Janicholson, 10-19-2006 13:32:58
Can't be that. Tractor has been stored inside barn for the past 7 years. Thanks for comment.
the tractor vet
10-19-2006 09:00:05
If and OLD M is tuned correctly they will start with a 3/4 dead 6 volt battery SOOOooo there for ya ain't got something wright or by chance it could have been flooded because of a leaking needel and seat . As stated OLD M's will start if ya can get the engine to turn a half turn . Case in point we or i should say that my buddy had and old M gas that had a mounded New Idea picker mounted on her that we sorta hopped up the engine with high alt. pistons and shaved the head with a 450 cam and on a warm day with a new Group 5 6 volt it started like it was 40 below well if the fan blade would make a half turn on anyday of the years that old M would start . So rules of tune up , propper points setting , propper plugs and gaps , propper timming and correct carb set , good battery and charging system good cables and connections Good clean gas and fuel system and your off and running . My old S/H will start down to -35 below but not at 40 below and when it is that cold i ain't screwen with it it can wait till it warms up.
John T
10-19-2006 08:45:41
Granger, yours is a wide open question and sounds mostly starter performance related, but may involve some ignition or other problems, but I will just address slow or weak cranking.....
The FIRST thing I would suspect is the battery, insure theres electrolyte above all the plates and that no cells exhibit a gray or milky color indicative of a weak cell and next give it a good slow full charge and better yet have a shop LOAD TEST it or try a know good substitute battery n see what happens????? ????? Next, if none of that helps much I would remove, clean n wire brush shiny, n reattach each n every battery n starter n starter switch n ground cable conenction n see if that helps. If the ground cable is attached to any thin or rusty sheet metal, maybe try it to a clean solid bolt somewhere????? ???
If still shes a slow cranker with a good battery n all good cables n connections, I would try to by pass the starter switch by using jumper cables to jump around/across it or just jump the hot ungrounded battery post direct to the starter n see if she cranks better then????? If by pass jumping around the starter switch improves cranking, I would suspect the switch.
Turn the lights on when cranking and if they dim wayyyyy yy down badly and/or the voltage drops drastically, I suspect the starter motor itself, but if theres not much change in voltage or light brightness, then I suspect the starter switch more.
FINALLY if the battery,,,,, ,,all cables n connections n grounds,,,,, ,,the starter switch are alllll llll okay but she cranks weak n slow, then I suspect the starter is at fault, maybe it just needs new brushes or the armature is dragging or otehr problems.
Sounds like it may simply be a cable or bad connection problem, so try that and check the battery condition first.
Let us know, best wishes n God Bless
John T
