Power steering fluid
GRuss
10-19-2006 08:16:31
What type of fluid should I be using for the power steering unit on my 1955 IH 300 Utility?
Nat 2
10-19-2006 09:04:43
 Re: Power steering fluid in reply to GRuss, 10-19-2006 08:16:31
Hytran.
The power steering is powered by the tractor's main (and only) hydraulic system, unless this is some aftermarket item we're talking about.
GRuss
10-19-2006 09:19:17
 Re: Power steering fluid in reply to Nat 2, 10-19-2006 09:04:43
Thanks for the reply. As far as I know it's the factory unit. I've only owned the tractor for a year and a half or so. The PS unit has what looks like a fill hole near the upper left below the dashboard when sitting on the tractor.
I've got a leak somewhere that I'm trying to track down...wet on the lines above the unit and looks like running down under the gas tank, also getting some on top of the battery. All the connections are tight so I'm not sure what's causing it. Any help is appreciated.
