806 and 2350 Loader
Chester in Mo
10-19-2006 13:50:33
Can anyone tell me if a IH 2350 loader will mount to an 806 without much problem. Is this a good match or is there a better loader for this tractor. Someone said that the 2350 mounts and dismounts very easy (quick connect). How reliable is this loader and is there anything in particular that one should look for when shopping for one.
cousin_gary
10-21-2006 10:57:38
 Re: 806 and 2350 Loader in reply to Chester in Mo, 10-19-2006 13:50:33
Good loader, will fix, makes tractor long though.
David A. Hodson
10-19-2006 16:32:32
the paper work that we got when we bought our 2350 says that the same bracket for the 66 series will work for the 06, 26, and 56 series with a 1/2 in thick spacer. "cause the 66"s frames are wider. the 2350 is one heck of a loader.
K.B.-826
10-19-2006 15:55:57
It will if you have the correct mounts for an 806, 1206, 856, 1256, or 1456. There were about a half dozen different mounts for that loader. It's a pretty good match to an 806.
