656 Gas Engine Knock
Dan Morancy
10-19-2006 16:55:49
My 656 gas has had a knock for about 2 years now. I have adjusted the valves and still does it. I am getting ready to tear down the engine. Any suggestions where to look? Thanks
dwag
10-20-2006 18:15:06
 Re: 656 Gas Engine Knock in reply to Dan Morancy, 10-19-2006 16:55:49
It"s called piston slap, too much clearence between piston and cyl sleeve. If knock has gotten noticeably louder, piston skirt is broke. Check piston and sleeve clearence on OH reassembly
Jim J
10-19-2006 21:14:33
We have a 656 our loader tractor in the (Salvage yard) That had knocked for may years. When I pulled it down, the timing gears were pitted up. Every other parts in the engine were fine.
MN Scott
10-19-2006 20:37:02
Either a scored sleeve or just a well woren piston sleeve assemblly. Been there done that. My 706 had a knock for 2 years, piston slap, when it warmed up it quieted down. Pulled it apart last winter and replaced the scored piston and sleeve and its quiet now, at least for a little while until it cooks itself again.
K.B.-826
10-19-2006 20:16:10
More than likely it's a wrist pin. Those engines are good for that, they've got tiny wrist pins. I'd pull it down, could really be anything.
the tractor vet
10-19-2006 19:53:38
You will find it when ya get her down then you can ask why this happened .
Brownie 45
10-19-2006 17:48:43
Is the noise at all speeds, or moreso at one particular rpm? Is it at the front or rear of the engine? Could it be loose flywheel / clutch department mounting bolts? Is the noise the same with the clutch depressed? How many hours since an overhaul? Could be pistons getting sloppy & out of shape in the bores-- excessive taper or that sort of thing. What happens if you pull a plug wire or two? does the knock get worse-- better? Try to isolate where the noise is coming from.
Brian in MO
10-19-2006 17:06:46
The first things that come to mind is rod bearing or a wrist pin at least that"s where I"d look. Brian
Delbert
10-19-2006 17:40:11
 Re: 656 Gas Engine Knock in reply to Brian in MO, 10-19-2006 17:06:46
Could be timing gears.
