574 Clutch Progress
BEWILDERED
10-19-2006 18:09:47
I got my tractor split today, went really well, less than an hour. Local dealer had the clutch in stock, but was just way to expensive. I told him what I could purchase one for at this site, but he would not budge on the price. I bought it here, I can wait a week for it to get here. I saw first hand how important the clutch return spring is and the proper free play. The man I bought the tractor from said it did not have one when he bought it, but it had a new clutch. The fingers on the pressure plate where all but gone. At least the flywheel was in great shape, no discoloration or heat checking. I think this is going to be a fun tractor. Thanks to all who have given advice so far.
FromJB2
10-19-2006 18:29:01
 Re: 574 Clutch Progress in reply to BEWILDERED, 10-19-2006 18:09:47
Hi Bewildered, good news that you can fix the clutch problem. Clutch return spring is very important, they often break and fall off without notice.
I think someone has already mentioned to mount pressure plate and clutch on the shafts, then put tractor back together then put bolts in pressure plate/flywheel thru inspection hole. Some people take the starter out so they can use a screw driver into the ring gear to turn engine over to get next set of bolts in flywheel.
Good luck
JB2
