IH300U Water Pump Packing Nut
Dellbertt
10-20-2006 15:35:19
Cooling system is all back together and seems to work fine. And yes, the thermostat goes in upside down which in this case is right side up :)
The front water pump packing nut(accessed just in front of fan)is a fairly large nut and seems to be quite loose and leaking some grease. I turned the the nut IN about a turn and a half. I assumed it is there to increase pressure on the packing.
Question: Is this nut an adjustment for the packing or is it supposed to be all the way in and snug.
Any thoughts? Thanks, Dell
Bill in oh
10-20-2006 18:56:06
 Re: IH300U Water Pump Packing Nut to Dellbertt in reply to Dellbertt, 10-20-2006 15:35:19
The large nut retains the pulleys on pump and yes it needs to be tight.The shaft packing is a type of round nut 4 or 6 slots in it that threads in end of pump right inside that large nut.if pump is'nt leaking coolant i would leave it alone. if it is leaking do'nt tighten very much.
