3 point on super a
banjo
10-21-2006 20:34:33
Are there any goog pictures of 3 points on the super a. I know i could copy one if i just had some good pictures to go by.I've got an old spring tooth tiller i think the super a could handle in the garden.At least i think that is the right name for it.
Marty Johns
10-22-2006 17:36:42
 Re: 3 point on super a in reply to banjo, 10-21-2006 20:34:33
farmallroy, how are you powering this unit, there is no pump at the pto and no tubing showing that you are useing a P steering pump! would like to see completed pic's for idea's to carry on!
Farmallroy
10-22-2006 18:06:20
 Re: 3 point on super a in reply to Marty Johns, 10-22-2006 17:36:42
Marty, it is lifted and lowered using the rod that goes up to the hyd. unit. I will see if I can find a picture showing the whole unit.
banjo
10-22-2006 18:02:56
Marty,The super a has its own hydraulics,touch control. if you look at the top left side of the picture you will see the arm that lifts the rockshaft.
Farmallroy
10-22-2006 04:50:53
third party image
This I built for my super a.
banjo
10-22-2006 18:05:38
 Re: 3 point on super a in reply to Farmallroy, 10-22-2006 04:50:53
Farmallroy, what are the lengths of the lower and adjusting arms? Do you have any problems with side movement(swinging)?
Farmallroy
10-22-2006 18:31:23
 Re: 3 point on super a in reply to banjo, 10-22-2006 18:05:38
third party image
Side movement was a problem till I added chains to the bottom arms. I use it every week to clean out the horse pens and I am very happy with how it works.
banjo
10-22-2006 10:46:22
Looks like some angle iron around the rockshaft thet the top link bracket is welded to. Are those the drawbar brackets the arms are attached to? Or are they custom made?
Farmallroy
10-22-2006 18:51:45
 Re: 3 point on super a in reply to banjo, 10-22-2006 10:46:22
third party image
Sorry I didnt answer your question on the brackets. Yes they are a set of drawbar brackets that I removed the factory pins from and installed the ones in the picture.
Farmallroy
10-22-2006 18:11:47
Banjo, yes you are correct it is 1 1/2" angle iron weled on the rockshaft. The vertical adjusting rods and the bottom arms are from TSC farm store, off the self items.
Hugh MacKay
10-22-2006 01:49:51
Banjo: Send me an e mail. Do you have a rear rockshaft? Therein lies the key to keeping cost down.
