to keep or not to keep
voager213
10-22-2006 13:58:59
my farmall h came with a loader but one of the cylinders is leaking i was wondering if it is worth it to keep the loader on it or just scrap it i want to use the tractor for pulling but would not mind unhooking the loader for the pull thats 1 time a year is this rare is the tractor worth more with the loader
Matt Page
10-23-2006 11:29:55
 Re: to keep or not to keep in reply to voager213, 10-22-2006 13:58:59
I don't know the exact type of cylinder thats on your loader, but the cylinders I've repacked have really been easy. Hardest part is getting them off and on and handling them if they're large. It's just a re-o-ringing job basically. Seems like mine were less than bucks apiece, maybe I misremember. I've done five, two the same, the others all different, all simple. Maybe I was lucky or maybe it's something that seems magical because most people don't try it.??. If you're thinking of scrapping it, take it down and look at it, price the parts... and then decide. Matt.
JayWalt
10-22-2006 20:25:28
From what I've seen loaders increase the value of a tractor to some degree (averages about 300-500). They also decrease the value of the tractor itself because of front end wear issues. If you can get the cylinder fixed cheaply (I've heard it is easy to redo the seals, aint done it yet), Then I would keep it. Loaders around here go for anywhere between 200-5-700 depending on the tractor its designed for.
Farmall freak
10-22-2006 15:17:08
You can have the cylinders repacked. Last time we had it done it cost about 300-500 dollars for someone else to do it.
K-Mo
10-22-2006 14:57:11
If the loader frame is in good condition, I would consider it to be a keeper. Usually new seals will fix a leaky cylinder.
