trying to identify IH wheel weights
Marks8N
10-23-2006 19:43:16
Bear with me I dont have a picture yet, I will explain a best as I can what the look like. They were bolted to the rear rims on my ford 8N.
They are red cast iron and have a IH in a circle in the casting, they a very heavy probably 100-150 lbs each, they are 16"-18" in diamiter, they are concave on the rear, and beveled on the face they have 2 half moon cut outs on each side and 4 bolt holes, they have a 8" to 10" hole in the middle. Are they front or rear weights and what do they fit???
My friend is going to take pictures of them so I can list on ebay, and I need to know what they can fit to list them, also does anyone have a clue what they might fit on and what they might sell for?? and help would be greatly needed.
Thanks: Marks8N
Unreserved dick
10-24-2006 19:18:17
 Re: trying to identify IH wheel weights in reply to Marks8N, 10-23-2006 19:43:16
If they are 18" or less in diameter, and especially if they have a non-circular hole for the axle, they are NOT the standard H/M/Etc. rear weights (for 36" rims). More likely they are the smaller weights which went with the 300/350 Utility (28" rims), or one of the Wheatland style tractors.
They should have a part number (something like 362656R1) cast into the weight somewhere. If you post that number, somebody should be able to tell you exactly what you have.
Unreserved dick
10-24-2006 19:21:29
 Re: trying to identify IH wheel weights in reply to Unreserved dick, 10-24-2006 19:18:17
Oops! Meant to say they aren't the standard H/M/Etc. weights if DO have a CIRCULAR hole for the axle.
arod
10-24-2006 12:03:17
the fellas answered it correctly, they are rear wheel weights for the Farmall letter series. Most common on the H and M. 145 lbs, just took a pair off my farmall H last week
AOOC
10-24-2006 07:42:22
They are 145 lb. cast iron IH weights. Should have four holes for mounting as well. Worth about 40 dollars apiece.
Richard Lisowski
10-23-2006 20:22:02
marks8n It sounds like you are looking at rear weights from a farmall A or B .I have a set I bought for 100.00 a set.
CNKS
10-23-2006 20:17:34
Sounds like rear weights that fit the C through 560. Look at some of those tractors on the tractor photo section, you can probably find them. Mostly C,H,M,Super series of the same, 300, 350, 400, 450, etc. I think they are bigger than 18 inches though, They weigh 145 lbs.
K.B.-826
10-23-2006 20:16:28
Sounds like they could be rear weights for a wheatland tractor, like a W-4, W-6, or W-9. Have your buddy post the pictures here first, and someone will tell you what they are for sure.
