another wild hair idea
Dave Mikkelson
10-24-2006 07:39:09
OK... its a little far fetched... but has anyone out there converted a old Farmall letter series to full hydrostat?
i.e. place a pump off the clutch in some manner and a motor inside the a modified trans or so.
Just curious... this hair still wiggles now and then.
Hayfarmer
10-24-2006 12:46:19
 Re: another wild hair idea in reply to Dave Mikkelson, 10-24-2006 07:39:09
It might be expensive but just think of the noteoriety? Sometime down the road someone would say here that Farmall once made a 300 hydro as experimental, like the infamous TA H.
dem45133
10-24-2006 14:11:20
 Re: another wild hair idea in reply to Hayfarmer, 10-24-2006 12:46:19
Hum... hadn't thought of that aspect.
Wardner
10-24-2006 09:36:33
To help you dream, get a catalog from Roberts Electric in Chicago. They have alot of variable speed pump/motor combos in different hp ratings.
I know next to nothing about Hydros but aren't most of them dual range? That would require a two speed gear box somewhere. I believe the pump would have to be a piston type with what they call a "wobble plate". That alters the stroke with a hand controlled lever.
Frankly, I would just buy something like a 544 Hydro and put letter series tin on it. If you are more ambitious, adapt a H-350 motor, frame rails , and bolster.
I think the whole idea is crazy but I am willing to humor you because I, too, have a few hair brained ideas. I am thinking about making a hedge clipper for one of my tractors. I have about 400 ft of 8ft high hedge.
David Mikkelson
10-24-2006 10:10:10
 Re: another wild hair idea in reply to Wardner, 10-24-2006 09:36:33
Yea... and by the time were done we'd find a working 544 or 656 hydro for less...
Just an idea... to make this old girl run her loader and clean her barn better... trip buckets and belly pumps will make one cuss when cleaning manure... but hey, it beat the H out of the pitch fork in the 40s. Still does.
Go for the hedge thing... I thought real serious about building up a similar contraption for my apple trees... Farm Show is full of wild hairs... every now and then we even think of something actually doable. A few are in my sheds too.
nballen
10-24-2006 10:48:57
 Re: another wild hair idea in reply to David Mikkelson, 10-24-2006 10:10:10
Not sure where to find one, or exactly what they are called, but somebody has already done "the hedge thing".
I'll probably ruffle some feathers with this, but the "lazy man's way" to prune / top an orchard is a device with rotating blades that "mows" all the branches off at a certain height. This is NOT a good pruning practice, but is quick and (at least in terms of manpower required) cheap.
The "mower" is a bad idea because it indiscriminately chops all the branches, leaving many stubs and stobs of dead wood (disease haven) in the tree. These stobs also will damage future fruit (especially soft fruit).
If you are serious about producing good fruit, take the time and prune the trees properly.
Nathaniel
dem45133
10-24-2006 14:29:17
 Re: another wild hair idea in reply to nballen, 10-24-2006 10:48:57
I know... thats why we didn't. These trees though are 30-70 years old. There was 16 of them in our front yard. Spans were 30-40 feet and 20-25 feet high. And they'd been prunned right every year before we bought the place. Apples out our ears if we sprayed and a frost didn't get the flowers. A three week ourdeal on ladders, pickups, ladders between pickups , ladders in the trees, any way we could.
But they were really stressing the old branch mains (to the point I'd brace them from the ground) so the other year everything less than 4 or 5 inches came off. Made about 10 ft diameter instead of 40 and 10-12ft high instead of 20. My wife swore I'd killed them, but being formally trained in ag and plant science... I knew they kick in the dormant nodes. I let them rebranch last 2 years only cutting the water shoots. This year we be back to pruning and spraying... but at 1/4 the work. Good apples... old hardy varieties.
