What plow is it
36 A
10-24-2006 16:06:22
Picked up a mounted two bottom plow it has IH stamped on it.The beam numbers are 513532R1 that is the long beam and 515003R1 is the short one.No tail wheel and the front mount is off set with a swivel that go"s up and down.A shaft with two pipes about 2"apart must be the mounting points and a chain on the long beam for the lift.Woundering if its for a C or super C.Any info about it will help find a good home for it.Thanks mark
mdntspec
10-26-2006 09:09:24
 Re: What plow is it in reply to 36 A, 10-24-2006 16:06:22
sounds like a C-294 or C-295 plow.... will fit C / Super C / 200 without fast hitch option
Hugh MacKay
10-25-2006 16:54:00
I looked at this yesterday, it's defintely not a Super A plow as the beam parts numbers are quite different. There were actually several plows that fall under your description. There were 2 bottom mounted plows for each of SA, C, SC, H, M, F-20 and F-30.
Not all SC had fast hitch. I only have parts listing for the SA plow
Cue P.
10-25-2006 09:29:20
Sounds like a plow for a Super A. I would think a Super C plow would have the fast hitch connection.
