H water pump question
farmallwayne
10-24-2006 19:27:50
Hello,
Can anyone tell me if the the water pump on an farmall H has Bearing or bushing in it. The reason I ask Is because it has some side to side movement in it And occasionaly hits the fan shroud. I AM PLANNING ON GETTIN A NEW WATER PUMP FOR IT BUT AM WONDERING IF A BUSHING IS WEARING OUT OR IF A BEARING IS GETTING READY TO EAT IT'S LUNCH, AS I NEED TO RUN IT TOMORROW.
Thanks
Brownie 45
10-25-2006 04:11:10
 Re: H water pump question in reply to farmallwayne, 10-24-2006 19:27:50
Do something before the fan goes through the radiator.
IowaFarmall
10-24-2006 19:52:29
There are 2 bearings inside the fan/generator pully setup on an H waterpump. I would guess these are shot unless the shaft they run on is terribly wore for some reason.
