Farmall H transmission
Jerry Schill
10-25-2006 03:20:41
I was on the H the other day and heard a fairly loud bang under my feet. It was loud enough to startle me. Engine continued running OK and so did the transmission, but now I can hear clicking when I"m in gear, especially going uphill or under a load. It seems to run OK in Reverse, 1st, 3rd & 4th, but haven"t had it in 2nd or 5th.
Any thoughts out there?
williamf
10-25-2006 11:33:25
 Re: Farmall H transmission in reply to Jerry Schill, 10-25-2006 03:20:41
It's hard to know what broke without you take the top off and see. Whatever it was, if it's still running it will likely get worse. It might just be a tooth chipped, and right now you only have to replace one gear. Good luck, Wm
dej(JED)
10-25-2006 05:26:00
I would bet that a bull gear cage broke from what you are describing. That isn't uncommon on H & M tractors with wear.
Jerry Schill
10-25-2006 11:31:03
 Re: Farmall H transmission in reply to dej(JED), 10-25-2006 05:26:00
If it is a bull gear cage that broke loose, is that something to be concerned about immediately? Is it OK to continue using the tractor?
Brownie 45
10-25-2006 04:07:12
I'd pull the top cover & take a look. Could be a ball out of a bearing went through a couple of gear teeth, or a piece of foreign material.
