Super C Carb question
JohnG(TX)
10-25-2006 08:41:27
I took apart the carb on a Super C that I recently got unstuck, and there was no venturi. There was the brass tube that feeds into the center of where it should be. I believe the previous owner ran it that way. Can this run without it, or should I really put one in? I thought it was funny when I took it apart, but this is the first SC I played with. All my other tractors (except the Regular) have a venturi. If I need one, anyone know where I can get one?
achodges1
10-28-2006 22:03:51
 Re: Super C Carb question in reply to JohnG(TX), 10-25-2006 08:41:27
Is it a Carter or a Zenith ? I have found several carbs on E-Bay. Some good some not so good.Some new.I ended up with a couple of doner carbs and extra parts. Craig
old
10-25-2006 11:14:16
With out it, it will never run as it should. I would try to find one for it. I'd start by calling a Case/IH dealer and then go from there
