Farmall 130 - bushhog
Ron Thomas
10-26-2006 07:42:15
I've a Farmall 130 with an aftermarket 3 point hitch and am in need of a bushhog for the same. Several questions: Is the tractor strong enough to pull a 4 or 5 foot bushhog? It's in excellent shape and runs very well. Are there any problems with the offset PTO? What type of adapter do I need to use?
Thanks for your assistance.
I'm looking at a Woods Brushbull 4' or 5' mower.
SuperA-Tx
10-26-2006 11:10:07
 Re: Farmall 130 - bushhog in reply to Ron Thomas, 10-26-2006 07:42:15
We run a five foot brush hog on our 140 without any trouble and have for years. The offset PTO is not a problem. Make sure you have a sheer bolt/bolts and you might want a clutch for the mower.
I saw they sold the clutches at this site. Kind of a handy thing but not something you have to have.
I have a cousin that runs a brush hog in his 140 and he has bent two PTO shafts but he does road mowing and is pretty rough on his tractor sometimes. I think his trouble is more of hitting ditches and stumps.
Ours are hooked up with fast hitches so I cant help much there.
daniel h.
10-26-2006 16:50:40
 Re: Farmall 130 - bushhog in reply to SuperA-Tx, 10-26-2006 11:10:07
I would add that an over-running clutch is a necessity on the 130 because the PTO is not live and if you push in the tractor clutch to stop the blades of the mower will have enough inertia to push you into a tree, ditch, pond etc. without the over-running clutch. The other type of clutch often associated with a bush-hog is a slip-clutch. This is totally different from an over-running clutch. The slip clutch prevents drive line damage when the blades come to a sudden stop from hitting a stump or rock. A shear pin serves the same purpose, and is cheaper initially, but more inconvenient as you have to change the pin every time it breaks.
gene bender
10-26-2006 10:38:43
get one that hitches to the drawbar with two wheels then you can hook behind the pto so the u-joints can run straight.
Hugh MacKay
10-26-2006 08:35:52
Ron: A Farmall 130 will have no problem with a 5 or 6 foot finish mower. Now, I've never run a bush hog on one of these little tractors, but I have on a 300. Big item I see about bush hogs is the shock loads created from hitting something a wee bit larger than normal. I'm thinking along the lines of stumps or chunks of wood, etc left from previous activities on the land.
Probably better from mower point of view than 300, as 130 will probably stall where a 300 would do damage. And just maybe my experience is not a fair test of equipment. My dad and I were clearing 10' to 14' high trees and bush 40 years ago. A hot shot salesman drove in suggesting he could cure our problems with a bush hog type mower. Well, he did for 3-4 hours then the 300 tore the mower to blazes. I'm not sure how he explained this damage to his superiors. We advised him that in the long run, chain saws and axes would probably cost less per acre.
Al -VA
10-26-2006 12:21:38
 Re: Farmall 130 - bushhog in reply to Hugh MacKay, 10-26-2006 08:35:52
Would not an overrun clutch protect against this.
Al
Hugh MacKay
10-26-2006 14:27:27
 Re: Farmall 130 - bushhog in reply to Al -VA, 10-26-2006 12:21:38
Al: My dad and I had our doubts that this was ever going to work. 300 had IPTO so over running clutch would have served no purpose. The over running clutch, only prevents machine from pushing you with transmission driver pto, should you depress clutch quickly.
Truth of the matter was a hair brain salesman came along with a mower heavy enough to mow tall grass. It was not heavey enough to cut small trees. The 300 did not suffer any damage. I doubt if they could have done anything with that mower besides send it off to the scrap yard. This mower was protected by shear bolt for overloads. My suspicion is they exchanged those for something better than shear bolt. I've seen salesmen try that one since a few times, usually creates a red face for them.
