Got my gascap, WTH?
JayWalt
10-26-2006 21:08:06
I'm not sure if the old cap on my 300u is stock. It doesnt lock and is a chrome color, with knurls on the edge and a slight dome on top, about 1" tall total. I got my new replacement cap (for free = ) ) so it will lock on. I havent put it on yet, but this thing is HUGE. It almost looks like an oil filter for a honda or something. It's black too, weird. Is everyone else's the same?
Dellbertt
10-27-2006 16:31:11
 Re: Got my gascap, WTH? in reply to JayWalt, 10-26-2006 21:08:06
I got mine in less than a week for my two 300u.
Not in a big hurry to put them on because I have the fuel gauge in the cap.
But they sure did some engineering on them. Must have been one helluva law suit.
HENRY E NC
10-27-2006 06:43:30
I got mine yesterday in a week afterm ordering. They are as you say, big and black. I am not sure I will use them though. The old ones have a vent and if you are careful not to overfill the tank there are no problems
Nat 2
10-27-2006 05:17:39
That's the way the caps have been since they started replacing them back in the '70s. Ever bought a replacement body panel for a car/truck? They come painted with black primer/sealer to prevent rust. It's normal, and I think the black paint is less obtrusive than bright red on a rusty old H or a white Cub, for example. Plus, they're free for the asking, so count yourself lucky that they didn't paint them hot pink :)
M clunker
10-26-2006 23:03:37
I got mine its the same that was on my m when i bought it. i lost mine in the hay field luckily the ser# has never been turned in.
JayWalt
10-26-2006 22:33:36
Well if it locks on there, ill use it. Should be easier to take off since its bigger. I rarelty look over the hood to see where my bucket is, more to the side anyways. I guess I shouldnt have ben too surprised, as they are probably only doing this because they HAVE to. They could have least painted them red =)
Brad in WI
10-26-2006 21:40:16
That is why the free replacements. The gas cap you have did not release the pressure inside of the tank causing excessive pressure and possibly fires or worse. The new ones are vented and are supposed to prevent fires or explosions.
RustyFarmall
10-27-2006 04:46:33
 Re: Got my gascap, WTH? in reply to Brad in WI, 10-26-2006 21:40:16
The original caps are vented also, the tractor will not run with a non-vented cap. The tall caps have baffles in them, to prevent the sloshing gasoline from spraying out of the vent hole and causing a fire.
Brad in WI
10-27-2006 05:12:53
 Re: Got my gascap, WTH? in reply to RustyFarmall, 10-27-2006 04:46:33
Guess I had one to many barley sodas last night. Makes a person think they are smarter than they actually are. I did know it was to prevent fires though. 8>)
RustyFarmall
10-27-2006 08:41:10
 Re: Got my gascap, WTH? in reply to Brad in WI, 10-27-2006 05:12:53
I knew, that you knew, that I knew, that you knew better.
banjo
10-26-2006 21:30:14
Yep, thats what they look like. It will grow on you after a while and you will not even notice it when you have to look around it to see over the hood.
