Hey Rusty...Fakin an MTA isn't that easy
wdrew24
10-26-2006 22:13:13
Hey ole buddy,
Was reading your responce to the MTA question. First, A 400 is not an M with different sheet metal. There are other things under that sheet metal that makes it somewhat different how the metal attaches to the tractor. 2nd...An M hood isn't long enough for a SMTA.
3rd...Only very early 400 castings will work because in 55 (As you know) the casting codes changed to "A" prefix.
4th...And probably most important to me...I must either know the tractor, the seller, or you better be able to give me some kind of history before I will buy a SMTA.
I looked at 7 different supposed SMTA-LPG's until Everything I needed to see came to fruition.
I have no problem with people who want one of these really bad, and the only way they can do it is to fake it. Just don't tell me it's the real deal if it ain't...ya know.
Kinda like the Super HTA that was never built...I would like to have one for conversation...but I would never pass it off as "Original".
Rusty man...your are a real "COOL" dude, I'm just bustin on ya little bit. God be with you.....DREW
D Slater
10-27-2006 11:01:10
 Re: Hey Rusty...Fakin an MTA isn't that easy in reply to wdrew24, 10-26-2006 22:13:13
Different things can be done and are done. But a lot of MTA that have non original parts I think were changed back when they were used for farming which some still are. Don't think of the made up ones there is to many out of them made up for money making purposes unless they get MTA parts cheap. If you have the parts unique to a MTA not counting engine and chassis , the MTA parts if in good shape and sold separate will bring a bunch. If you count time labor and paint in most cases you just as well buy the real thing. Above just an opinion on my part. I see more F 400 being past off as F 450 than MTA.
dej(JED)
10-27-2006 06:59:36
What makes you guys think everybody out there wanting a SMTA is aware of casting codes etc.
A lot of guys don't give a darn about codes. That is for the IH police. I know body guys that wouldn't have a bit of a problem lengthening a hood and you wouldn't be able to spot it from the original. I have seen several SMTA's made out of 400's.
John A.
10-27-2006 04:48:10
Drew, Morning! "Ditto"... Read my post down below and hollar back at me and let me know what you think. Later,
John A.
RustyFarmall
10-27-2006 04:43:20
I didn't say it was easy, but I know it can be done. Hoods can be lengthened, serial numbers can be altered, and casting codes can be ground off. A SMTA seems to be valued among some collectors at a considerably higher value than a 400, so the work involved in creating a SMTA is very well rewarded. Personally, I think it is a shame that some folks would do this, I feel that the 400s need to be preserved also. For what it is worth, I will never attempt such a thing.
Hugh MacKay
10-27-2006 07:17:42
 Re: Hey Rusty...Fakin an MTA isn't that easy in reply to RustyFarmall, 10-27-2006 04:43:20
Rusty: The value of a tractor perceived as rare, is rather interesting. The 00 and 30-50 series tractors have some of the lowest production numbers of any tractors built by IH, yet sales figures and price at time of sale would never indicate they are anything like rare.
In the case of the offsets, a good Super A or 140 will command far better prices than 100 or 130. A good Super C will always fetch more than a comparable 200 or 230. There was over 100,000 each of Super A and Super C built, yet none of the others except 140 topped the 25,000 production mark by much.
The 300, 350, 400 and 450 are much the same, none ever exceeded 25,000 by much, yet they don't stand out at auctions commanding big prices. I had a friend e mail, about 4 years ago asking if I could find him an SMTAD. I found 3 and they were all pushing $10,000. In my travels I also found a 400D, 2- 450D and 3-560D each with a price tag under $5,000.
Then there is the Super A1, only 1,957 ever built, yet I'll bet if you did a poll right this hour, of the names that appear on Farmall pages 1, 2 and 3, 90% couldn't give the specs of a Super A1.
CNKS
10-27-2006 14:27:46
 Re: Hey Rusty...Fakin an MTA isn't that easy in reply to Hugh MacKay, 10-27-2006 07:17:42
No one said tractor collecting had to make sense on a practical or useful basis. SMTA's, although horribly over priced are overpriced not because of the numbers produced (too many to make any sense), but because they were the first IH tractor with a TA snd independent PTO, and were made for only one year. Yes, the Super A1 is much more rare but the only difference between it and the Super A is 10 more cubic inches, a standard water pump, and taller radiator, which resulted in a taller grill and higher sheet metal. But, I will probably buy one (if reasonable) even if alongside a 130 or a 70's 140, just because. The 460 high utility I am working on (may never finish the thing) is one of only around 800 built. I might even get my money back on it from a knowledgeable buyer; but it's no $10000-$15000 tractor, because like the A1, few people have heard of it and it doesn't have a following.
Hugh MacKay
10-27-2006 02:20:27
Drew: I agree with you in that a 400 is not and M with different sheet metal.
The SMTA however is nothing more than a 400 with SM sheet metal. IH did the same with Super A1, only 1,957 of them ever built and again nothing more than a Farmall 100 with SA sheet metal. Sure people are faking them. Until 5 years ago I had never seen a Super A1, and I've been around since before these tractors were built. Now, folks seem to be finding any number of Super A1. 5 years ago if you asked at YT 90% of folks didn't know SA1 existed.
The laughable part in all this is folks turning a 400 into an SMTA. If your looking for rare tractors, there are already less 400 around than SMTA's. By the way I doubt if Rusty said as you suggested.
Stan(VA).
10-27-2006 09:49:51
 Re: Hey Rusty...Fakin an MTA isn't that easy in reply to Hugh MacKay, 10-27-2006 02:20:27
Hugh,
I think the SA-1 would be better described as a 100 with Super C sheetmetal. It did have the taller radiator, grille, gas tank mounts, and longer hood. More of a unique grill as the A/C grill bottoms are cut different. You're right on with the perceived rareness idea and the laughable nature of a conversion based on the x00/x30/x50 tractors. They just don't seem to have the same appeal. I have done plenty of custom creations just for the education (like a B with hyd's and a 3pnt, SC with 230 hyd's, SC with a 140 motor, 230 Utility, SM stage1&2) and don't have a problem with that at all; but don't try to pass it off as something it's not. Anyone that asks about mine I tell where the parts came from.
Several years ago I was admiring a very nice H on full steel at a show, looked it over and noticed that the hand written sign listed it as a 1937. Since it couldn't be a '37 thought I'd be helpfull and look it up for him. SN and a few casting codes I checked all matched for a '40 model, even noticed it still had the early 1-1/8" PTO. Just a nicely cleaned up original looking tractor. So I watched for the owner to relay the 'good' news. Big mistake. I approached him privately, he got red and started yelling "IT'S A 39!, IT'S A '39!" (by now I realized it was meant to read '39, just a sloppy digit). I meant it as a complement and wasn't intending to argue with him so I just dropped it and didn't understand the response until later when I saw him trying to sell the tractor to someone. Then it was a 'rare' 1st year production model and he didn't want to be confused with the facts.
Stan(VA).
Hugh MacKay
10-27-2006 12:37:28
 Re: Hey Rusty...Fakin an MTA isn't that easy in reply to Stan(VA)., 10-27-2006 09:49:51
Stan: I can agree somewhat with SC sheet metal on the 100, then I thought about confusing folks thinking cross between SC and 100. I guess better words would have been a Super A1 is just a Farmall 100 with letters series sheet metal.
I remember once driving 200 miles to see an excellent Super H, one of those that had to be seen to be appreciated. When I arrived here was a tractor with 3 major shades of paint. It had band brakes, and one could see the complete rear chassis was from a different era. It had complete stage two SH live hydraulics and I think complete with a C-169 engine. I say think as soon as I raised the issue of it being built from 2 tractors, maybe 3, he wouldn't let me get close enough for a positive ID of anything. Told me I was wasting his time. I said, "Sir it wasn't you who drove 4 hours here and another 4 home just to try and do business with someone who knows little or nothing about a Farmall tractor."
Another colleceter friend of mine told me he bought the tractor 2 years later fo $400. He told my friend the Super H is just not a very popular tractor.
Allan In NE
10-27-2006 03:58:11
I was looking at a real clean, authentic SMTA yesterday with original paint. First one I had ever laid eyes on.
You could just see the evaluation of the IH tractors. Looked like a "half-grown" 560. :>)
Allan
BOBM25
10-27-2006 09:29:49
 Re: Hey Rusty...Fakin an MTA isn't that easy in reply to Allan In NE, 10-27-2006 03:58:11
Really, the FIRST one you've ever seen? They must have been sold more in some areas than others. I have a legit SMTAD and I know a gentleman 15 mi from me with another. He said his father bought it brand new. Several guys around still have gassers and they've always been on same farm. I guess I don't consider them "rare". Heck, check the numbers on the 6 and 7 series ant-eaters, those I would consider rare. We should figure out how to build them, we'll be millionaires in 30 years when they are "antiques"
jordan gutnik
10-27-2006 11:10:23
 Re: Hey Rusty...Fakin an MTA isn't that easy in reply to BOBM25, 10-27-2006 09:29:49
I see there is a SMTA-D and a SMTA gas for sale in the classifieds here on this site. Wonder if the prices are in the ball park or too high??
