Order Farmall Cub Parts Online
tire pressure on Front Cub
Farmallb
10-28-2006 05:23:53
The fronts of my 48 Cub say 60/70lbs air, With the front end being light to begin with, why so high a pressure??
Jim Becker
10-28-2006 06:53:10
 Re: tire pressure on Front Cub in reply to Farmallb, 10-28-2006 05:23:53
The pressure marking on the tire sidewall is the maximum the tire is rated for. It has nothing (or at least very little) to do with what pressure is required when they are mounted on a Cub. Correct pressures are listed in the Owner's Manual. For the front of a Cub, 25 is good.
