I have two 300U and changed the hydro screen in both. It is located under the seat. The drain is on the left side near front bottom. Its a two man or one man and a hoist to lift the top half of the resevoir. The screen is about the size of a paper towel cardboard wrapper. Be VERY careful when lowering the top back on as its easy to crush the screen and they cost between $65-100 if you can find one. Clean the resevoir good while in there and you might put new o-rings in the valves. I was luck enough to get an original parts manual and the original operators manual with one of them. The screen number is 364687R91. I would scan the parts pictorial for you but my scanner isnt working at the time. The last parts book I bought at Case/IH dealer for a Case 1030 was $26 they might be more now but it is available and is what you need. Dell
