Re: Farmall 300 Clutch Adjustment
John's 300
10-29-2006 05:43:01
I recently purchased a 300. Got a shop manual and I adjusted the TA and the clutch at the same time. I notice now that when I go up an incline (small hill) and the TA is in the forward position, I push the clutch in and I can't get it out of gear. Works okay with the TA pulled back. Is this just something I have to live with it or did I miss something in the adjustments? Any help would be appreciated.
John
D Slater
10-29-2006 07:41:26
 Re: Farmall 300 Clutch Adjustment in reply to John's 300 , 10-29-2006 05:43:01
Your T/A clutch is not releasing, double check your adjustments and if you still have problem shorten the link between main clutch shaft and T/A clutch shaft 1/2 turn at a time until the problem goes away. If that takes care of it when finished Put T/A handel forward pull the pin in short link. Then looking at tractor from left side turn T/A clutch shaft one to rear of tractor counter clockwise until you fell release bearing contact pressure plate fingers then turn shaft back until pin will line back up. This is to make sure release bearing is not running agianst fingers all the time. If theres no free travel left after shorting that link or it still won't come out of gear the T/A clutch itself may have a problem.
RustyFarmall
10-29-2006 06:00:39
I don't know a lot about TAs but I would say that you missed something in the adjustment procedure.
