Red Tractor collector bug..Cure???
A4T1RAT
10-30-2006 14:14:52
well I have come to the relization that I have a un cureable disease.some how my shop is full of these red tractors. what do I do ? I have a 856, 706, 3414 plus parts. the only thing I can think of is build a bigger shop? any ideas? also I have just found a 1456 that needs a home and for some reason i know i will have to rescue it is there any cure of should I just make more room? also is there any thing to look out for on a 1456, did the make a lot of them.. thanks guys
OM
10-31-2006 16:57:46
 Re: Red Tractor collector bug..Cure??? in reply to A4T1RAT, 10-30-2006 14:14:52
Red fever is the worst, there is no cure so I just keep on collecting
Farmall freak
10-31-2006 13:08:16
You are very lucky because ever since I saw my first tractor and their reliability I wanted every one I could find. So far I have three Farmalls cub, C, M, a ford 4000 and a JD 410 diesel backhoe. Except for the Cub and M all of these tractors have been around the old farm since I can remember. So at 15 I have these trators and have to build some storage before I find any more. I have it so bad my mother has banned tractor talk in the house.
Lloyd Llama
10-30-2006 17:02:26
Boss man says there's no cure. Says the best you can do is to try to keep the symptoms down with a new infusion of red tractors in yer barn every so often. He ought to know, he has two colors that are buggin' him!
old
10-30-2006 15:19:22
Boy your lucky you only have the red fever. Shoot I have red, orange, 2 grren brands and a bunch more. Spent most of the day tring to get as many as I could in the sheds for the winter. You know doing that ends up being a lot of work?
glennster
10-30-2006 14:38:15
i got that same affliction. any old machine that needs a new home with tlc. when i ran out of room, i just bought another farm with more sheds on it..... hmmm they are starting to fillup too.....
Harley
10-30-2006 19:00:14
 Re: Red Tractor collector bug..Cure??? in reply to glennster, 10-30-2006 14:38:15
There is no known cure. There is a short term remedy, it's called d-i-v-o-r-c-e-, but it's only temporary till after court, and then you're right back at it. Harley
