Buddies Pulling M
DCPULLER
10-30-2006 17:03:45
A friend of mine took the head off his M he bought for pulling. He was told it had a M&W crank and 4 1/4 bore. Upon pulling the head he discovered the sleeves where removed and the bore is 4 1/8 with 1/2" high domes. the piston moved 5 3"4 down to bdc, M&W stroker crank? The counter bore in the block was never filled which resulted in cranking preasure of 130 to 145 psi. Fill me in not used to working on the reds! Dave S
D Slater
10-31-2006 07:16:32
 Re: Buddies Pulling M in reply to DCPULLER, 10-30-2006 17:03:45
Stock stroke 5 1/4.
M&W stroker cranks sold for M were 1/2 inch over stock.
Randy in NE
10-30-2006 17:47:56
You might want to pose this question over on the pulling board. They are more inclined to do "unconventional" things with these old engines.
VOLfarmall
10-31-2006 02:43:57
 Re: Buddies Pulling M in reply to Randy in NE, 10-30-2006 17:47:56
How do I get to the pulling board? Thanks for any infro.
Randy in NE
10-31-2006 10:21:58
 Re: Buddies Pulling M in reply to VOLfarmall, 10-31-2006 02:43:57
If you click on Discussion Forums in the Community box to the left and then scroll down to Tractor Pulling. This is one site. I have never been here so don't know how good it is.
