Culti-vision
Roger Mills
10-31-2006 11:31:23
Separate decal sets shown for Culti-vision, how do you know you have one?
Roger Mills
11-05-2006 08:50:03
 Re: Culti-vision in reply to Roger Mills, 10-31-2006 11:31:23
Thanks, I guess it was because you could see what you were about to cultivate. Anyway, I just wanted to know which decal set to use. I bought a restored "A" at a farm auction for $900. It is gas only and has an overhauled engine, new tires, belt PTO, adjustable front end and Ball jar pre-cleaner, short exhaust with spark arrestor. I had to install a new wiring harness and new lights which were missing. It has the IH magneto and runs perfect. SN FAA 103,333 and matching engine #. Oil pressure, (using a different gauge), runs 55 lbs. and idles at 18 lbs. when hot. Unfortunately I will have to pull the drives off and put in new brake bands. Other posts later and pics. Thanks again.
teddy52food
10-31-2006 17:16:38
B was cultivision also.
City-Boy McCoy
10-31-2006 13:12:07
Culti-vision is an IH marketing name for the tractors with the off-set design, like the cubs, A's, Super A's, 100's, 130's and 140's. I believe the term was primarily used in conjunction with the A/Super A tractors. If you have either of these tractors, you have "cultivision". However, by 1951 (at the latest) the cultivision decal was replaced by a decal with white background which just read "Super A". Others may contribute more accurate information than I have provided here.
mike
