Power Steering went out omn my 1066?
dej(JED)
11-01-2006 05:11:13
The PS went out on my IH 1066. It does nothing at all. The fluid is clean. Any ideas on how to fix it would be appreciated.....
agrogers
11-01-2006 14:22:06
 Re: Power Steering went out omn my 1066? in reply to dej(JED), 11-01-2006 05:11:13
Had the same thing.
Blown O-ring in one of the pressure ports of the MCV. Took longer to drain the oil, pull the valve apart, hee and haw about what it might be than it did to actually pop in a new o-ring and put it all back together.
Could be other stuff too, just my experience.
the tractor vet
11-01-2006 10:09:55
You have PTo ???? and does everything else work ??? If the PTO works and the tractor drives i would be thinking that maybe a sticking valve pluge steering orfice blowen O/Ring - gskt . in the MCV . low on fluid > just some ideas as i can not check it myself .
neblinc
11-01-2006 05:28:10
Here is a link to an older post on things to try.
Randy
