w-6 standard
wegman in Mn
11-01-2006 19:31:06
I want to build a sw-6 standard high crop. which means i would have to find a salvageable mv for the drop housings I think i may hane some bolster problens because of drag link arms. how would i go about puting on the high crop front axle?
Harold H
11-02-2006 06:49:51
 Re: w-6 standard in reply to wegman in Mn, 11-01-2006 19:31:06
I have never heard of a high-clear wheel type tractor. However, if you are determined, anything can be done. You will probably find it easier to find cotton picker parts than high-clear parts. For the rear end, you could use cotton picker flanged housings and bull gears to raise the rear. If you didn't want to use Farmall type rear wheels, you could use dual wheel hubs and disc type wheels. You will also have to find a M thru 560 reversable top and reverse your rear end. As to the front, a Farmall High Clear axle would have to be extensively modified because it has a complete different mounting system and steering syetem. Might be easier to somehow modify the spindles on the SW-6 axle. Have fun with your SW-6-HC project.
Harold H
Vollmer
11-02-2006 05:58:03
I am looking for a site that will tell me about International I-9 It is a industrail tractor with cab and bull dozer. I am wondering what it's value is. I just run into this site and wondering if I could get some help on finding information
