113/123 governer
banjo
11-02-2006 05:58:01
I was wondering if i can convert my super a to a C with the governer? I installed the 3 1/8 pistons and sleeves when overhauled. Just wondered how they accomplished the extra ponies with governer speed.
gene bender
11-02-2006 16:46:26
 Re: 113/123 governer in reply to banjo, 11-02-2006 05:58:01
You went from 113cuin to 123cuin no change in the gov is needed. If you want more rpms just back off the cap screw on top of the gov next to the input lever.
banjo
11-02-2006 20:23:35
 Re: 113/123 governer in reply to gene bender, 11-02-2006 16:46:26
Thanks, this one just doesn't seem to wind up like my other super a that was overhauled several years ago by someone else. I set the governer by the book according to the linkage and throttle all the way forward.
gene bender
11-03-2006 02:41:32
 Re: 113/123 governer in reply to banjo, 11-02-2006 20:23:35
is the input shaft worn and sloppy as that makes quite a difference they can be rebushed then throttle response will be correct. Just bore out the hole and install a 5/8X1/2 brass bushing mite have to trim the length a little after installing.
banjo
11-03-2006 07:06:39
 Re: 113/123 governer in reply to gene bender, 11-03-2006 02:41:32
would have to check and see, just have a few other irons in the fire right now.
