farmall 450
Bill vandevende
11-02-2006 10:01:33
Hi guys I just got a farmall 450 and it has a broken valve the block has 281 stamped on it but when I ordered the valve for the 281 it was the wrong one it was longer than the one I took out I had to order the valve for the 264 are the heads for the 281 and 264 interchangable because this doesent make much sence I was thinking that someone changed the head at some time the ser# on the fly wheel houseing tag is 523-S can some one give me some insight thanks for your help
Bill vandevender
11-03-2006 07:55:52
 Re: farmall 450 in reply to Bill vandevender , 11-02-2006 10:01:33
The # on the head is 362174-R1 the # on the block is 356980R2 by the way this is the first farmall I have ever worked on I got the tractor given to me by an old farmer that had it stored in his barn for years all I had to do was pay to get it hauled to my house I usually work on the ford N tractors but this was a deal I couldnt pass up thanks for your help because I really dont know much about the farmalls
D Slater
11-03-2006 09:41:47
 Re: farmall 450 in reply to Bill vandevender, 11-03-2006 07:55:52
Thats the correct head for 450 and 400 gasoline engine. They must have sent wrong valve.
D Slater
11-02-2006 13:13:57
Several heads from M SM 400 450, 6 SW6 and 400 450 W series tractors may be installed on your tractor. Best to measure Valve length when ordering. Also look in middle of head under valve cover for a casting # and post back, someone will let you know which head it is. A few heads will have # stamped on right side of head. C 281 engine serial numbers started at 501 and if both are gasoline fuel tractors the head for C264 in a 400 tractor and C281 should be the same if not replaced.
D Slater
11-02-2006 15:36:35
 Re: farmall 450 in reply to D Slater, 11-02-2006 13:13:57
Thought I better add this, the C-264 engine serial numbers started at 501 also but in the SM tractor. Serial number 136834 was first serial number for a C-264 in a farmall 400. On original gasoline heads the SM used a shorter valve than 400 on C-264 engines. You may have a kerosene or distallite head though. Good engine parts place can tell most times by valve length on those heads which one you need.
Wardner
11-02-2006 10:55:07
There are four different valve sets for the C-264 and C-281 depending on fuel and serial number. The gasoline engine changed its valves at motor number C-13685 and again at 161366. All 450's were sent from the factory with motors above C-161366.
You should have given the parts man the casting number on the head to avoid any confusion. It seems likely he asked for it but did the best he could using the model number of the tractor.
Wardner
11-02-2006 11:04:21
 Re: farmall 450 in reply to Wardner, 11-02-2006 10:55:07
Correction, not that it makes any difference.
C-13685 should be C-136835 in previous post.
It appears that your head was not originally installed on the tractor. Someone replaced it with an earlier head.
Bill vandevender
11-03-2006 08:27:55
 Re: farmall 450 in reply to Wardner, 11-02-2006 11:04:21
sorry I think I posted wrong before
Bill vandevender
11-03-2006 08:31:58
 Re: farmall 450 in reply to Bill vandevender , 11-03-2006 08:27:55
