340 rowcrop vs. 340 utility
Al L. in Wisc.
11-02-2006 17:13:35
Seeking knowledge as to the differences between the 340 rowcrop and utility. Is it more than just the wide front? Thanks in advance for repies.
Hugh MacKay
11-03-2006 03:45:32
 Re: 340 rowcrop vs. 340 utility in reply to Al L. in Wisc., 11-02-2006 17:13:35
Al: You did ask the differences, and JJ and a lead covered the steering and front end well. There were options on hydraulics as well but I think the same applied to both Utility and Farmall.
On power train from crank pully to the tip of pto shaft the two tractors are identical except for rear axles and pto drive gear ratio. The axle housings will be the same. Most utilities developed 540 pto at a bit higher engine rpm. This also increased ground speeds to compensate for smaller tires.
As to that side hill bunk, old is correct, Farmall chassis is actually less than 2" higher than a Utility. I think max. wheel tread setting on a Utility is around 68" wheras the Farmall will quite easily go to 90" wheel tread. NO THANK YOU, but I'll take the Farmall for side hill work any day. When these tractors were new most Utility buyers were running wheel treads 56" to 64" for convenient use in confined areas. Farmall buyers were running 72" or wider wheel tread for row crop work. Let me assure you a Farmall at 72" wheel tread will be a mountain goat along side a Utility at 60" wheel tread. Tractors loaded with chloride are also much more stable on side hills.
J.J. from Afton
11-02-2006 21:37:32
The 340 rowcrops and 340 utilitys also have comlpetely different steering systems. The utility has a steering rod on each side of the engine, while the steering shaft of the rowcrop goes along the left side of the engine. Rowcrops have adjustable axles, utilitys dont. Also the utilitys could have the muffler go through the hood or under the axle, almost all rowcrops went through the hood.
a_lead
11-02-2006 18:06:49
I got the owners manual out: Pictures show the front bolster area is different. The hydraulic pump return tube goes directly into the hydraulic filter plate. The front lights are on the very front on the utility, next to the operators platform on the Farmall. Engine exhaust is downward and back on the ut not thru the top. Farmall had either cast iron or power adjust rear wheels, ut had 3 types: Disc wheels with demountable rims, one piece wheel & rim assmbly, or power adjust type. The front bolster weights are different. The book shows different wiring harness's for each. General dimensions list the ut as 3" shorter length, narrower min. width & max width, ut is 4" shorter to top of steering wheel, lower to ground on belly side. Turning radius 9' on the ut, 7'3" on the Farmall. Guess I got carried away on the long post. Sorry. Edward
Brian Y.
11-02-2006 17:46:22
Al, posted a few entries earlier is a photo I posted of a Farmall 340....(the rowcrop versions of IH"s tractors were the Farmall versions; the utility models were the International versions). As far as mechanical differences, I am not sure of any-transmissions,engine HP,etc. But the utility models had a shorter wheelbase because the front axle was swept back, and because(as in the case of the 340)they had a 28" rear wheel; thus the utility model sat lower-making it more stable on hillsides and in a loader.Hope this may have been a help.
old
11-02-2006 17:39:58
Don't quote me on this but I think the row crop one sits a lot higher then the utility one does. I know the row crop one sits up about as high as an H does.
