4 cyl. version of 301 6 cyl
The Farmall
11-02-2006 18:09:16
I know there is a 4 cylinder version of this motor. same block but hack off 2 cylinders. What did it come in? Was it in a tractor or combine or was it more or less a stationary power plant. I heard it was used in a utility tractor like a 74 or 84 series tractor but not sure. Any help on where to look for this type of motor. thanks Ryan
Duner Wi
11-03-2006 06:23:46
 Re: 4 cyl. version of 301 6 cyl in reply to The Farmall, 11-02-2006 18:09:16
C200 used in 544,574,674,2405B,2500A,2510B,2514B,2544,2500A and 8000 forklift. Internal engine parts are pretty much the same as C 301.
CNKS
11-02-2006 19:12:05
I may get canned, but I'm going to say that didn't happen. I think the 74's and for sure the 84's were mostly made in Great Britian. They were diesels like the 301. The 4 cylinder version of the 301, if it exists and assuming the same bore and stroke is about 200 cu in. The gas version of the 544 has a 200 cu in 4 cylinder engine, I don't think they are related, but I don't know the origin of the C200, either. The D301 is a successor to the C221 used in the 460, which in turn was derived from a 30's (I think) International truck engine. All of this can be corrected by someone else who may actually know what they are talking about.
Buzzman72
11-03-2006 07:08:10
 Re: 4 cyl. version of 301 6 cyl in reply to CNKS, 11-02-2006 19:12:05
As far as the truck engine you're referring to, the C-221, C-263, and C-301 are derivatives od the SD-220 and SD-240 truck engines which debuted in the 1950 L-series International trucks. These engines begat the BD-220, BD-240, and the BD-264 later in the '50's, and in the '60's became the BG-221, BG-241, and the BG-265. [The BD-308 truck engine wasn't related to these engines, but was based on the BLD-269 family of engines].
CNKS
11-03-2006 09:24:52
 Re: 4 cyl. version of 301 6 cyl in reply to Buzzman72, 11-03-2006 07:08:10
Yes the place I bought my C221 engine kit from said the truck version was the 220. I thought the guy said it was used in the late 30's, but I didn't think it would have been that "old" a design, which would have made it older than the H and M engines, not that it makes any difference. Interesting anyway.
CNKS
11-02-2006 19:16:21
OK, the two posts below were done as I was typing mine, I totally withdraw my statement and it is getting close to time for bed -- but at least I got the 200 cu in right, and now I know the origin of the 544 engine. Didn't know the 84 series had gas engines either -- think I better stick to the letter series.
K.B.-826
11-02-2006 19:31:47
 Re: 4 cyl. version of 301 6 cyl in reply to CNKS, 11-02-2006 19:16:21
CNKS- As far as the British Utilities that we have here in the U.S. go, the transmission/rear end were built at the factory in Doncaster, then shipped to Louisville, where the tractor was fully assembled using German diesels or U.S. gassers. I don't think a gas engine was an option on any of the 84 series Utilities. As far as the origin of the C-200 goes, it is based off of the C-221/C-263/C-291/C-301/D-236/D-282/D-301 family. There was also a D-166 four cylinder, a D-188 based off of the D-282, and I believe a C-175 based off of the C-263.
CNKS
11-03-2006 06:31:19
 Re: 4 cyl. version of 301 6 cyl in reply to K.B.-826, 11-02-2006 19:31:47
Thanks, I learn things everyday. I just didn't think IH ever chopped 2 cylinders off any of their engines, no reason they couldn't. As usual, whenever I assume something, I am wrong. In my last post I did not intend to include the 84's, as I wrote up the specs for a 784 for my former employer, in the late 70's and knew that they did not come with gas. As to the 263/175, you have also told me where the 175 came from. I get lost when I see gas engines in tractors that are not derivitives of the A/B/C..404, H..350, M..450, etc. Thanks--no more assumptions, foot in mouth doesn't taste very good, but sometimes people have to learn from their mistakes.
K.B.-826
11-02-2006 19:05:11
Yes, it's the C-200. The 544 tractor had it, along with a few of the British-built utility tractors like the 574. It was also sold to other companies for use as a power unit, in things such as large air compressors.
mowr
11-02-2006 19:01:00
IH 544, 574 and 674 gas tractors. I believe it was used in some combines and several industrial applications; air compressors, forklifts, etc?
