How does the oil get into governor
FarmallBob
11-03-2006 14:25:26
How does the oil get into my governor on my Farmall C, and super C? Where does it come from? Thanks!
Bob
Brownie 45
11-04-2006 10:39:51
 Re: How does the oil get into governor in reply to FarmallBob, 11-03-2006 14:25:26
Don't remember for sure, but I believe the oil is pushed uot of the front cam bearing & is thrown or carried by the gears up into the governor area. After leaving the front bearing, it is more or less a splash system.
banjo
11-03-2006 16:16:37
the timeing gears mesh with the governor gear. oil travels around the gears.
FarmallBob
11-03-2006 16:38:37
 Re: How does the oil get into governor in reply to banjo, 11-03-2006 16:16:37
Banjo, yes I know, but where is it coming from? How does it get onto the timing gears? I have never seen any bijure drip system in there, and when I get into the timing gears and the governor to make repairs, it seems drier than it should be. Thanks for your in-put.
Bob
YTSupport
03-07-2009 07:14:08
 Re: piston clearance in reply to Janicholson, 03-05-2009 18:30:17
Please ignore, recovering the board by replying to top message.
FarmallBob
11-04-2006 06:33:10
 Re: How does the oil get into governor in reply to banjo, 11-03-2006 18:35:02
Banjo,
That's OK, know how it is Because I do it sometimes myself. The next time I am in there, be taken a better look. Thanks!
Bob
