Freeze Plug Installation ?
TritonTom
11-03-2006 15:57:33
I will be installing new freeze plugs in the A this weekend. The new plugs from Case IH are concave. Which way does the curve go, in or out. Thanks, Tom
El Toro
11-04-2006 03:45:30
 Re: Freeze Plug Installation ? in reply to TritonTom, 11-03-2006 15:57:33
At onetime you could get replacement freeze plugs made from neoprene and you tightened them with a wrench. Hal
Doc Larry
11-04-2006 06:05:24
 Re: Freeze Plug Installation ? in reply to El Toro, 11-04-2006 03:45:30
Napa still carries them. I couldn"t find the right size disc style plug for my Case (unless I wanted a box of 100) and the adjustable rubber works fine.
Larry
El Toro
11-04-2006 07:10:30
 Re: Freeze Plug Installation ? in reply to Doc Larry, 11-04-2006 06:05:24
I haven't used any of them for a long time and I wasn't sure they were still available. They were ideal in an area where you couldn't smack the metal plugs with a hammer.
The metal plugs are prone to rust if you don't keep rust inhibitor in the antifreeze. Permanent antifreeze doesn't mean forever. I usually change
it every other year.
When I was a kid my dad always used Zerone that was an alcohol antifreeze. Used it over winter and drained it in the spring. Never had any radiator clogging problems like they do now. When we got an H Farmall it had the Zerone too.
The 10-20 we had was always drained after use in the winter months and that radiator never leaked.
Hal
Doc Larry
11-03-2006 16:24:38
If the plug is cup style the concave side out should be out.
If the plug is disk style, it goes concave side in, after which you need to flatten the center 1/2 of the disk with a hammer - don't overdo it.
Larry
Allan In NE
11-03-2006 16:13:48
Tom,
If it is just a "plug", install it with the bow out. When you have it correctly in place, smack 'er in the middle with a good sized drift to spread, lock, seat and seal the gizmo.
Allan
banjo
11-03-2006 16:13:19
you want the dome to the outside. It will be a loose fit so you will have to peen it till tight. Some put a dab of sealer on it first then peen it till tight.
TritonTom
11-03-2006 16:17:35
 Re: Freeze Plug Installation ? in reply to banjo, 11-03-2006 16:13:19
Thanks for your help, guys. That makes sense, and thats why the old ones looked different. Thanks again, Tom
Allan In NE
11-03-2006 16:20:02
 Re: Freeze Plug Installation ? in reply to TritonTom, 11-03-2006 16:17:35
Tom,
If the old ones were the "cup" type, I really wonder if the plugs will work.
The plug types need to rest up against a ridge in the bore. Cup types don't.
Allan
