Finally uncovered my serial number I think.
Patrick Martin
11-04-2006 14:02:09
I decided to start sandblasting the bellhousing and transmission on my 100 today and discovered that there really are numbers on the little tag riveted to the bellhousing! HA! :)
I didn't hit it with the sand but the overspray did help clean allot of the crud off the tag. It's faintly stamped like this:
2064 J
1575
Now I don't know wich one os the serial number or what the J is???? The markings on the tag are gone so it's just a sliver tag with these two numbers. Guess I'll have to get a repro and restamp it or something? Maybe not since it's not a big deal as long as I know what they are.
sammy the RED
11-04-2006 20:21:55
 Re: Finally uncovered my serial number I think. in reply to Patrick Martin, 11-04-2006 14:02:09
Yours is a 1955.
tractorsam
11-04-2006 14:26:58
I don't know the 100's really well but I think you'll find the top number is your serial No. and the 'J' indicates a Rockford clutch. Have a hunt under serial No.s on the left for the year, I imagine it's a 55 with a low number like that. The lower number is max no load RPM. Hope this helps, tractorsam
Patrick Martin
11-04-2006 18:30:06
 Re: Finally uncovered my serial number I think. in reply to tractorsam, 11-04-2006 14:26:58
Well I checked and it doesn't cover any letter codes?????
What's a Rockford clutch? Some kind of special clutch?
tractorsam
11-05-2006 05:43:29
 Re: Finally uncovered my serial number I think. in reply to Patrick Martin, 11-04-2006 18:30:06
When your tractor was built I think there was an option on the clutch. It was either an Atwood(I think) or a Rockford. Nowadays I think you'd be hard pressed to find parts for the Atwood or even a tractor that still had one. I don't believe they were ever as good as the Rockfords. Hope this helps, tractorsam
Janicholson
11-04-2006 15:58:18
 Re: Finally uncovered my serial number I think. in reply to tractorsam, 11-05-2006 05:43:29
You were close, It was an Auburn clutch that had no J in the #. the J does mean Rockford. (unless you find NOS, you will buy a Rockford replacement. JimN
Patrick Martin
11-04-2006 18:32:18
 Re: Finally uncovered my serial number I think. in reply to Janicholson, 11-04-2006 15:58:18
????? ????? OK....so do I have a Rockford or an Auburn?
Is a Rockford some sort of special clutch????? ?
Janicholson
11-05-2006 21:28:28
 Re: Finally uncovered my serial number I think. in reply to Patrick Martin, 11-04-2006 18:32:18
J means Rockford, that is what you have. It was a different supplier, and considered heavier duty. Not much different though in terms of wear or power to connect the engine. It makes no difference as they (replacements) are all Rockford type now. JimN
Patrick Martin
11-05-2006 22:12:42
 Re: Finally uncovered my serial number I think. in reply to Janicholson, 11-05-2006 21:28:28
OK I gotcha now, well that's pretty cool to know! :)
