Re: My M does not start HELP!!!!!!!!!!
Hey John
11-04-2006 16:56:57
If everything is new can I change to positive ground, what is better?
John T
11-04-2006 17:37:47
 Re: My M does not start HELP!!!!!!!!!! in reply to Hey John, 11-04-2006 16:56:57
You can change to whatever ground your lil heart desires and it will still work PROVIDED..... .
You Polarize the genny before start up You swap ammeter leads if it reads bass ackwards
You swap coil leads if its backwards
HOWEVER THERES NO ADVANTAGE OR REASON TO DO SO if its ONLY a non spark problem (fix that first)cuz you need to solve that FIRST so you dont mess up the VR if the gennys isnt correctly polarized. Lets solve one problem at a time before having to change battery polarity which requires an ammeter and coil lead swap and re polarization. Even if its not the correct polarity it can still spark so lets get it to spark first then we can worry about polarity or non charging
Good Luck,
John T
