Re: My M does not start HELP!!!!!!!!!!
Hey Nat
11-04-2006 17:15:21
The more info. I receive makes my think, I'll replace everything,Coil condenser pionts coil regulator plugs,cap. I think it may be bad ignition switch, it looks rusty and I have no power to either side of coil when ignition is on. What do you think
El Toro
11-05-2006 03:54:13
 Re: My M does not start HELP!!!!!!!!!! in reply to Hey Nat, 11-04-2006 17:15:21
You need to find out why there's no voltage at the coil. Check the the ignition switch for voltage output, if there's no output voltage check for voltage coming in to the switch. If there's voltage present at the input side of the switch,your switch needs replacing. No voltage to the switch you need to keep tracing that feed wire back to the voltage source. Some are fed voltage from the starter solenoid and that wire could be broken.
You can run a separate hot wire fron the battery to the coil to see if the engine will start. I wouldn't be replacing parts until you find the voltage problem. If you're using negative ground
the wire from the _ negative terminal on the coil should go to the distributor. Clean those points too. Hal
