Farmall A Oils, Lubricants
Tyler cohrs
11-04-2006 17:35:37
Hi ive got a farmall A and would like to change the oils in the Transmission and final drives. Just want to know a good way to flush the old out and what Is best to put back in. Also what are the capacities for these. Thanks Alot.
billde
11-05-2006 05:27:09
 Re: Farmall A Oils, Lubricants in reply to Tyler cohrs, 11-04-2006 17:35:37
Use 85-140 if you live in a warm climate, 90wt for cold climate
vally farm
11-04-2006 20:13:10
Every Old Timer I know has told me to drain it out, fill about 2/3 to 3/4 with kero or deisel and drive her around for a few minutes...Gear boxes only! Some say to flush the engine the same way, but ron the moter good and warm, drain and fill with kero to propper level, run her for 15 to 30 sec. MAX. After flushing out, drain WELL - get every last drop out, then fill with new fluid and go. Mike
JayWalt
11-05-2006 06:46:53
 Re: Farmall A Oils, Lubricants in reply to vally farm, 11-04-2006 20:13:10
DO NOT run the tractor with diesel in the rear end. Block her up and putter in neutral and turn the rear end by hand for a bit. There needs to be as little load on the gears as possible or they will wear like butter even for a short time.
turbos10
11-04-2006 18:17:30
test
BigMarv1085
11-04-2006 18:04:52
Final drive (each 1.5 quarts), transmission (5 quarts) add pint for pto or belt pulley.
