706 shifting problem
SteveGr
11-05-2006 05:31:56
I just acquired a 706 and found that it would not stay in high range , it would jump out under aload. I checked the external linkage and that appeared fine. I manually shifted it on top of the cover and it still jumps out. I pulled the top cover which I found to have been replaced and could find nothing out of whack. I then looked at the shift collar and could see no problems, also looked at the high gear splines and could see no excesseive wear. I then manually slid the shift collar and engaged high range and started the tractor and put a load on it and it did not jump out of gear and worked fine. The shift fork had been built up but appeared straight. open to any ideas. Thanks in advance.
Sheepdog in NE
11-04-2006 15:39:24
 Re: 706 shifting problem in reply to SteveGr, 11-05-2006 05:31:56
So did you look under the lid where the arm, spring and roller is? That roller in the notch of the cam is what holds it in gear. Do you feel it fall into the detent as you shift? The cam comes off by removing the snap ring on the shaft that goes thur the cover.
