still stumped
voager213
11-04-2006 09:32:13
ive been trying to figure out what is a causing my H to idle so funky actually it dosent idle at all the only time i can get it to idle is when i first start it and then when i throttle it up it will come down but it wont come down anywhere near idle any info on this?
Brownie 45
11-07-2006 18:21:54
 Re: still stumped in reply to voager213, 11-04-2006 09:32:13
If the other guy's suggestions don't solve the problem, see if the throttle plate has ever been removed & put on upside down. Throttle plate has both edges chamfered on opposite sides of the plate where they meet the edges of the throttle bore. Second suggestion- check for binding in the governor to throttle tube[ it's adjustable].
the tractor vet
11-04-2006 17:46:27
I would say that the two bushing on the arms where the gov. spring goes are GONE , so if ya pull the side plat off the gov. and the spring just sorta flops around and the whole look big then they need to be rebushed . Now those bushings have to be made and i always use bronze also they must have a small chamfer on both sides . When i need one rebushed i have a friend that works on clocks and he has this neat littel machine shop in his basement and he makes them up and press fits them . He was having the same problem with his one S/MTA as we call it the old one as he has two and it would not ideal down well on nice sunny afternoon we got into it and i showed him what the problem was and i pulled the govener off and took it apart and we went to work an and hour later it was back on and working like a swiss watch so he now knows how to make them and just how i want them and has done a bunch for me.
RustyFarmall
11-04-2006 11:11:33
Vacuum leaks, worn parts in the governor, worn throttle shaft in the carb, throttle linkage out of adjustment. All of these things can cause those symptoms.
Jossette
11-04-2006 10:45:11
timing
