B250 W4
EmileE
11-04-2006 18:56:14
Does anybody know if the heads off of a IH B275 or 414 fit on an IH B250 .Also on the mc cormick W4 I just purchased there is a plug half way up the clutch housing and another one on the bottom .Does this mean it is an oil bath clutch and if so what type of oil would be used.Would appreiciate any information I could get.
John M
11-06-2006 03:11:08
 Re: B250 W4 in reply to EmileE, 11-04-2006 18:56:14
CAnt help on the head, but the W4 does not have a oil bath clutch.If this plug is below the starter its the plug to give you access to grease the throwout bearing, if its,if its closer to the clutch pedal, then its the full level for the transmision lube.
