Super M swinging drawbar
RoninKS
11-04-2006 19:35:20
After installing a Saginaw 3pt. on my recently aquired SM, I also bought a used swinging Farmall drawbar for it.
After everything was mounted, the drawbar is level (and at a right angle to the 3pt),.... but the end of the swinging drawbar is only 10"-11" from the ground. Is that normal, or should it be higher?
Thanks,
RoninKS
CNKS
11-04-2006 19:58:46
 Re: Super M swinging drawbar in reply to RoninKS, 11-04-2006 19:35:20
Never noticed it before you mentioned it, but mine is 12 inches to the top of the swinging part. I don't see any problem, better too low than too high. I suppose you could drill holes (with difficulty) in the 3 point frame to raise the U part an inch or two. The swinging part of mine is angled down slightly, meaning that the 3 point mounts a little lower than the drawbar would without the 3 point.
RoninKS
11-05-2006 20:49:07
 Re: Super M swinging drawbar in reply to CNKS, 11-04-2006 19:58:46
CNKS, Thanks for the reply, and I agree that lower is better than too high.
I notice when I pull my Donahue trailer and a few other things, that the hitch seems pretty low, I guess that won't really cause much of a problem unless the front of my Krause disc digs into the ground when I pull it in the transport position.
If I had another drawbar, I'd seriously think about bending it and welding it to the top of the existing one (over the "TOP" of the roller), which would gain me a few more inchs of ground clearance.
I'm curious to see it others have also had low drawbars after installing a Saginaw 3pt., and if it has caused them any problems with their implements.
RoninKS
