exhaust manifold opening size on an M farmal
ss_impalla
11-05-2006 22:18:52
the tapped hole in the top of the exhaust maninfold is what? 2" pipe tap ? My brother in law has an International 20/40 I think. Does it have the same exhaust opening? His manifold bolt hoses are all screwed up so I was thinking about cleaning up the threads in the manifold and screwing a piece of pipe in it to hook a muffler to. He's already let the tractor lock up on him once from water getting in. Luckily, I used some PB Blasterand let it sit a few days and got it freed up again. Does anyone know where I can get a tap that size to chase the threads with, without breaking the bank?
Janicholson
11-06-2006 06:09:54
 Re: exhaust manifold opening size on an M farmal in reply to ss_impalla, 11-05-2006 22:18:52
Tool Rental companies save you money on an item you may use once. Be sure you are not cross threaded. JimN
mark geiger
11-06-2006 03:40:29
I had the same thing I went to my local plumber and used his with pb rust buster on the tap and worked great.
Dave S.
11-06-2006 02:12:35
The pipe is 2". Try www.harborfreight.com, they have a set(11/4",11/2",2") for $60.
