New Tire Time for the A
John P.
11-06-2006 04:08:32
My newly aquired A needs new front tires. It has the adjustable front axle with non-adjustable front wheels. Which tire size am I better off getting the 4.00-15 or 5.00-15 tires?
City-Boy McCoy
11-06-2006 04:44:10
 Re: New Tire Time for the A in reply to John P., 11-06-2006 04:08:32
I would say 4.00's if you have the 9.5x24 rears, and 5.00's if you have 11.2x24 or larger rears. I had a 140 with 9.5's on the back and it squatted with 5.00's on front.
What do you have on the front now? Do you like them?
mike
John P.
11-06-2006 05:05:56
 Re: New Tire Time for the A in reply to City-Boy McCoy, 11-06-2006 04:44:10
I have not yet got it running so I don't know, but it has a 5.00-15 on one side and a 600-15 car (VW?) tire on the other. Primary use will be for towing a wagon through the woods loaded up with wood.
old
11-06-2006 07:26:56
 Re: New Tire Time for the A in reply to John P., 11-06-2006 05:05:56
The bigger tires will help you in soft ground and help keep the front from digging in. Also watch how you load a trailor with fire wood or you might stand it up on its back tires. BTDT and found you have to laod the trailor the right way or you will do wheelies
John P.
11-06-2006 07:43:35
 Re: New Tire Time for the A in reply to old, 11-06-2006 07:26:56
Yup, always scared of that happening. In fact that is why I prefer a wagon vice a trailer. I was having the same feelings about the wider tires on the soft ground myself. I figured as long as they fit ok on the 15x3" rims that might be the way to go.
old
11-06-2006 07:48:00
 Re: New Tire Time for the A in reply to John P., 11-06-2006 07:43:35
Had a B years ago and was hauling fire wood and I had the front wheels off the ground a few time. Even with a wagon if you get it to loaded down you could stand one up. Just be careful and be safe. Its better to make 2 trips then to end up flipping one over
John P.
11-06-2006 08:52:54
 Re: New Tire Time for the A in reply to old, 11-06-2006 07:48:00
I take it you had quite a load and a lot of ballast?
old
11-06-2006 09:43:15
 Re: New Tire Time for the A in reply to John P., 11-06-2006 08:52:54
Well it was a small trailor. Bed was about 4X6 and had side boards on it that where about 3 foot tall. I had it heaped up on the trailor and I started up a hill. Ya the hill is what caused the problem.
