'40 H COUNTERSHAFT REMOVAL
rd/oh
11-06-2006 08:36:43
What is the procedure to remove tranny counter shaft after the main shaft is removed? thanks in advance. This is a great site for answers RD
rd/oh
11-07-2006 03:54:37
 Re: '40 H COUNTERSHAFT REMOVAL in reply to rd/oh, 11-06-2006 08:36:43
D Slater Thanks you very much. That was the info I was needing. Ron
D Slater
11-06-2006 19:29:09
On rear of counter shaft there is a retaining ring for rear bearing. Remove PTO and ring, move clutch and brake shaft far enough to one side for bearing to be driven rearward off shaft and out of housing. Remove hydraulic pump drive from front of shaft(right hand threads),remove bearing retainer and seal housing,move shaft to rear out of bearing. Work shaft out the top.
