1969 international 340 utility tractor
ruth challoner
11-08-2006 12:52:57
We purchased a used 340 utility tractor, but did not get a manual with it, would like to know where the power steering fluid goes in at and what the resevoir on right side of tractor by the distributor cap is for , is it oil or what, would appreciate some help. thanks
Fred Mills
11-10-2006 08:23:59
 Re: 1969 international 340 utility tractor in reply to ruth challoner, 11-08-2006 12:52:57
There is a gear box on my 1963 IH 340 with power steering.It is located just forward and under ths dash. It has a top fill plug that is difficult to get to. Takes gear oil and most leak. The arms connecting to the steering rods come out of this housing. I was told to never let it get dry.
Hope this helps.
a_lead
11-08-2006 17:36:04
Should be a plug on the side of the transmission housing, most likely on the LH side for fill level indicator on the transmission (Hytran/Hydraulic) fluid. Not sure of where the fill hole is, some of the of the others will be able to tell you where that is. Hope fully the year that you indicated is a typo; 1958 to 1963 production years for the 340"s.
old
11-08-2006 13:11:47
The one up front and low sort of in front of the distubutor is for engine oil. And as far as the pwoer steering if its like the 340 I have the fluid goes in by the shifter, you use hy-tran fluid there. The power steering nd other hyds use the same pump and also the same fluid
