Pulling sleeves
Fancy Farm
11-08-2006 17:34:07
I am trying to pull the sleeves out of a 354 perkins and so far I haven't been able to budge one any tricks? Can you bust them out?
barnrat
11-09-2006 07:36:32
 Re: Pulling sleeves in reply to Fancy Farm, 11-08-2006 17:34:07
I have a fancy sleeve pulling tool($800 used)made by OTC That sits on the top of the block and pulls them using a bottle jack. If you can't find one of them taking it to a machine shop is your best bet they can pull them. Sometimes the sleeves crack at the base, then a machine shop can bore them out. Plus a machine shop can clean up an dress the holes so new sleeves will go in better. Don't forget to freeeze those new sleeves and pull them out of the freezer right before you put them in.
brianriver
11-08-2006 19:43:38
You can break them out if they are the cast iron ones but you have to be very careful not to gouge the block as you do it with a cold chisel. You may want to take a long punch and sharpen it to a 45 degree bevel and work it easy. If the sleaves are chromed steel liners, you can run 3-4 beads of weld from the bottom up being careful to put a very saturated cloth shop rag over the crank journal to prevent pitting of bearing surface. This can be done on a cast iron liner as well. As the beads cool, they draw the liner in and help break the pressed fit. Be sure to hone clean the block to remove any scale or rust when reinstalling liners and clean the block flange well to prevent the top of the sleave from breaking as you seat it. These sleeves do come out hard, but if you have to take it to a machine shop to press out, it means that you have to remove engine from tractor. Can try on cyliner first before going press out route.
El Toro
11-08-2006 18:53:44
Have your local auto machine shop pressed them out. You can have them install new cam bearings too. Hal
