Order Farmall Cub Parts Online
Using a newer Crank in a 53' cub
Kurt in Va Beac
11-09-2006 09:36:16
I have a 1953 cub, in about 1000 pieces. I am currently working on rebuilding the engine. I got a new crankshaft for it, but it is slightly different (has counter weights) then the one I took out(which is like the one in YT's online store). The cast number is 357247R1 on the new one. I don't have the 53 part number on me, but it is different. I do know the new one is for a C60 engine - I think it is just a newer replacement. The question I have is, can I use this new crank in my 53 cub? thanks
Jim Becker
11-09-2006 16:03:25
 Re: Using a newer Crank in a 53' cub in reply to Kurt in Va Beach, 11-09-2006 09:36:16
Probably from a power unit, maybe a later tractor. It should work OK. I would set it in place and rotate it to verify clearance between the counterweights and the engine block.
Kurt in Va Beach
11-09-2006 17:00:06
 Re: Using a newer Crank in a 53' cub in reply to Jim Becker, 11-09-2006 16:03:25
Thanks Jim! Block goes tomarrow to shop to be rebored.
john cub owner
11-10-2006 20:38:05
 Re: Using a newer Crank in a 53' cub in reply to Kurt in Va Beach, 11-09-2006 17:00:06
Before you reassemble, make sure it has the end bored for a pilot bushing. if not take it to a machine shop along wth a bushing.
