Magneto Problem
ste_fano
11-09-2006 12:38:22
I put new wires, plugs, rotor, cap, points ect on my B. Just learning, have learned alot from all of you! Tried to go by the book, and put the wires in the cap back in the book picture order, # 1 being at about 2-3 o'clock on the cap, then 3,4,2 clockwise. I should of tried to find TDC, but didn't. Anyway, got very little spark. Redid point gap about 100 times!!, checked plug gap too, had little spark from mag wire to cap. Finally found a diagram I drew when I took the wires off the cap. Wire #3 was at 2-3 oclock, then 4,2,1 clockwise. It fired right up. What is the reason for this? Did the farmer put the mag in a few teeth off? Is it ok like this? Hope I explained it right. Thanks, Steve
Dan in Ore
11-10-2006 04:53:34
 Re: Magneto Problem in reply to ste_fano, 11-09-2006 12:38:22
If it ain't broke, don't fix it. That mag will run just fine 1/4 turn off.
JT
11-09-2006 15:03:00
My B is running and starts real easy and it runs with the wires on the plugs one hole off.
Yugrotcart
11-09-2006 13:33:32
The 2 ears on the mag are not in the correct position with regards to the mag drive. No worries, mine is out by 1/4 turn as well. Won't harm anything. To have it correct, bring no. 1 cylinder to TDC on the compression stroke. Turn the mag til it is pointing to the "correct" no. 1 position, and all will be well.
Paul
